pshow
Nov 27, 2021Follower
Adding a smart plug
How do I turn off the 5.0 so I can connect a 2.4 smart plug? I have a MR60
Nov 27, 2021Guru - Experienced User
the only MK series that you can seperate the SSID's is the 80 series.
But you shouldn't need to shut it off to connect a smart device.
Just have your phone on the 2.4ghz for setup. Some phones you can set a preference (and change it back afterwards), others you can just be far enough away and disconnect/reconnect.
