bogdanpavlov
Jul 10, 2016Aspirant
Admin Password Doesn't Work for USB readyshare drive
Admin login/password is denied when accessing a hard drive connected to the modem via USB that was read/write protected in routerlogin.net. If the drive is not protected, no problem accessing via...
Raiden64
Aug 09, 2016Aspirant
I have the exact same problem, I can access folders without password protection enabled, but as soon as i enable password protection read/write I'm unable.
Even if i have password protection on and try to access the folders LOCALLY, i'm unable to because it won't accept my login credentials.
I assume the username should be "admin" and password my Routers login password.
Thanks in advance.
DexterJB
Aug 10, 2016NETGEAR Moderator
