bogdanpavlov
Jul 10, 2016Aspirant
Admin Password Doesn't Work for USB readyshare drive
Admin login/password is denied when accessing a hard drive connected to the modem via USB that was read/write protected in routerlogin.net. If the drive is not protected, no problem accessing via...
Raiden64
Dec 18, 2016Aspirant
Still am unable to access Readyshare locally, any update on when this problem is going to be patched?
Nighthawk R8500
My firmware if you're curious # V1.0.2.86_1.0.75
DexterJB
Dec 21, 2016NETGEAR Moderator
- bobcadeJan 22, 2017Tutor
I resolved this problem tonight. I tried all of the others solutions with managing windows credentials or turn off password protected sharing or enable 40 or 56 bit encryptopm but what resolved it for me was simply changing the routers admin password to something new after I had the readyshare configured. Hope it helpes someone else.
- BlueghostApr 16, 2017Tutor
That partially solved my issue. However, I have some of the shared folders setup with read access with no password and write access with password. When accessing the read-only folder via windows, I still had to enter the router admin credentials.
- rovaaaMay 13, 2017Aspirant
This issue is driving me nuts.
1st question: how do I even know what the password of my admin account should be? I never created one explicitly. Admin = common user account?
2nd question: How come I can't connect with smb://admin@1.2.3.4/readyshare with any password that could be my admin account? Also for me it seems that admin protected folders dont work
Please help.
- TxB0yApr 09, 2020Initiate
From post 15 of this thread stiil applies with R8000P router Firmware: V1.4.1.50_1.3.10. You will need to reset the admin password after setting up the readyshare. Note there is nothing stopping you setting it back to your perferred password afterwards.
- mont27Jun 30, 2020Aspirant
I have this same problem - my foscam stopped transferring files and I could not get the ftp login to work no matter what I tried. After wasting two days trying to solve I saw this thread and tried changing the admin password and now it works - somehow that must have triggered the ftp process to pick up the new password (or ??). I have an r7800 running version V1.0.2.68 and this is June 29, 2020. I would think Netgear would have fixed this 2016 problem by now...
