bogdanpavlov
Jul 10, 2016Aspirant
Admin Password Doesn't Work for USB readyshare drive
Admin login/password is denied when accessing a hard drive connected to the modem via USB that was read/write protected in routerlogin.net. If the drive is not protected, no problem accessing via...
JohnKn13
May 25, 2020Aspirant
Same issue, but I don't see any solutions yet. Curious if someone found a workaround.
- TxB0yMay 26, 2020Initiate
Change the password once more. After you have deployed readyshared device.
- JohnKn13Jun 06, 2020AspirantI've tried everything in this post. None of these solutions work to access a password protected folder.
- Slimdog320Aug 22, 2020Aspirant
When I tried to map the drive connected by USB it asked for admin password so I kept trying the username:admin and password.
It worked when I changed the username to readyshare and used the admin password.
