bogdanpavlov
Jul 10, 2016Aspirant
Admin Password Doesn't Work for USB readyshare drive
Admin login/password is denied when accessing a hard drive connected to the modem via USB that was read/write protected in routerlogin.net. If the drive is not protected, no problem accessing via...
Phclem
Jan 04, 2018Initiate
I had the same problem on my R7000, where I had set the admin password using some special characters ($). After several changes, I noticed that the readyshare mapping is rejected if my password contains the $ sign, but works fine if the admin password is "less sophisticated" ! Hope this will help some others ...
najevi
May 31, 2020Aspirant
I agree. Alphanumeric passwords {i.e. limited to: a-zA-Z0-9} appear to be successful but any password made more secure {eg. by using: ~!@#$$%^&*()_ } are successful only when accessing the NETGEAR Web-based Router Configuration Utility but not succesful when accessing a \\readyshare network folder that has been secured with "admin" access controls.
- Incidentally. I did test the sequence where a plain alphanumeric {admin, password} pair is first used successfully and only then change to a more secure {admin, pa$$word} pair using a special character however, each time a special character is introduced to the admin password any subsequent access from Windows 10 file explorer to a readyshare network folder fails to recognize the more $ecure pas$word.
Help Center quote:
Available Network Folders Table
This table shows all the Network Folders currently available and configured on the Router:
- Folder Name : Full path of the used by the Network Folder
- Volume Name : Volume name from the storage device (either USB drive or HDD)
- Total/Free Space : Shows the current utilisation of the storage device
- Share Name : The Name shown in the Router Web GUI can either be clicked to immediately access the storage or can be entered into a web browser e.g //readyshare/photos. If 'Not Shared' is shown then the default share has been deleted and no other share for the root folder exists.
- Read/Write Access : Shows the permissions/access controls on the Network Folder:
- All - no password allows all users to access the Network Folder
- admin will prompt for users to provide the same username and password used to access the Router Web GUI
bold underline added
If this bug is to be fixed then please let the fix involve specifying a {username, password} pair for readyshare that is different than that required for the admin account for the NETGEAR Web-based Router Configuration Utility. Sharing these admin credentials with LAN users (who understandably require shared folder access) is a gratuitous invitation for curious local network users to go poking around the router configuration utility and potentially meddle with critical router functionality/security.
Even better would be for the "admin" username to be user customizable. After all, who is going to think of trying to hack your router secured using something like "ScoobyDoo" as an admin user name and then, say, "M!cr0$)ft" as your password?
OS Name: Microsoft Windows 10 Home (64-bit)
OS Version: 10.0.18362 N/A Build 18362
Browser Firefox 76.0.1 (64-bit)
Router Version R8000
Firmware Version V1.0.4.28_10.1.54
GUI Language Version V1.0.4.28_2.1.49.1
