bogdanpavlov
Jul 10, 2016Aspirant
Admin Password Doesn't Work for USB readyshare drive
Admin login/password is denied when accessing a hard drive connected to the modem via USB that was read/write protected in routerlogin.net. If the drive is not protected, no problem accessing via...
interestica
Oct 01, 2020Aspirant
Eventually got it with registry change:
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\LanmanWorkstation\Parameters
CHANGE -----> AllowInsecureGuestAuth from 0 to 1
schumaku
Oct 01, 2020Guru - Experienced User
interestica wrote:Eventually got it with registry change:
This does allow the client using a non-authenticated access, so called guest access. How shall this fix the _authenticated_ access using the admin (not as per the subject Admin) username?
