Tazmarge23
May 24, 2017Follower
Admin password
I am trying to use the genie app and says the admin password is default but it won't work. What do I do?
DexterJB
May 29, 2017NETGEAR Moderator
Hi Tazmarge23,
1. What is the model number and firmware version of your device?
2. What version of the Genie app do you have installed?
3. Have you tried using another device (iOS, Android, computer)?
4. Are you able to login to the router UI using a browser with the default logins?
5. Have you tried resetting the device?
Dexter
Community Team
DexterJB
Jun 01, 2017NETGEAR Moderator
Hi Tazmarge23,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
