Dadspet
Dec 06, 2018Aspirant
After firmware update NETGEAR68-5-G2 no longer visible
I updated the firmware on V6 R8000 to latest level V1.0.4.28_10.1.54 . Prior to this netgear68-5G-2 channel was visible and after the update its no longer visible. I've updated the firmware several ...
- Dec 08, 2018
Previously I did a factory reset twice and it didn't resolve the 5G-2 issue. After the last post asking if I did a factory reset , I decided to try it again and it still didn't work. Finally, I decided to try it one more time and for some reason, this time it worked and I now have a 5G-2 channel and my performance has also improved a lot. Not exactly sure why it took so many factory resets but my thinking is the last time I held the reset a lot longer and that must have been the key. After the last reset, I had no internet connection but I did have a 5G-2 signal and powering of my modem didn't get the internet back. I had to call Comcast and they did a modem reset to get me back on the internet ( that might have improved the connection speed).
Mikeee111
I have been having this exact issue since the latest firmware...haven't found a fix yet.
michaelkenward
Dec 07, 2018Guru - Experienced User
Two thoughts.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
Second suggestion, if problems persist, you can revert to the previous firmware.
There is support for the R8000, including a manual and firmware, somewhere at the end of this link:
>>>>> R8000 | Product | Support | NETGEAR <<<<<
- DadspetDec 08, 2018Aspirant
