jman_2o21
Jul 22, 2021Aspirant
After Purchasing Armor I Get An Error "Logon timed out, please try again. If this issue persists..."
After purchasing the Armor "upgrade", the app continuously times out, no matter which fix I try. The specific error is, "Logon timed out, please try again. If this issue persists, try rebooting you...
Jul 22, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App and know how to work it better than those of us who follow this "general router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Good Luck.
- jman_2o21Jul 22, 2021Aspirant
Thank you for the reply. Unfortunatly that forum has no threads related to this issue that are not "solved" with an excuse about COX being the ISP.
Others are experiencing this issue and getting responses in this forum. I am going to try the method described here and let you all know if it worked:
