JohnnyBravo2
Aug 18, 2016Tutor
AirPrint Enabling
Just bought Nighthawk R8500 and trying to make my Samsung printer AirPrint capable. The simple issue is I don't see an "AirPrint" menu option in the Genie App as all the documentation states and shows...
JohnnyBravo2
Aug 18, 2016Tutor
Its not natively an AirPrint Printer. If it was it wouldn't need the router to make it capable. I am trying to get the documented process that states "will make non-compatible AirPrint printers now AirPrint capable".
Regardless of my printer type the main menu option in the genie App does not have an "AirPrint" option contrary to the documentation that shows it. So I can't even attemp to choose my printer model.
- aveerlapatiAug 20, 2016Aspirant
make sure u can print wireless from ur pc/mac using readshare printer app and ur printer drivers are installed
- DexterJBAug 22, 2016NETGEAR Moderator
Hi JohnnyBravo2,
1. On which device do you have the NETGEAR Genie installed?
2. What version of NETGEAR Genie do you have installed?
3. You may find the link below helpful.
http://kb.netgear.com/app/answers/detail/a_id/20913
Dexter
Community Team
- DexterJBAug 26, 2016NETGEAR Moderator
Hi JohnnyBravo2,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
