goclmbmnt
Dec 10, 2017Tutor
Airprint stopped working - R7000
I get an error message on my ios devices when I try to print to my non-airprint compatible printer setup through the router. It used to work great. I loved it. I'm not sure when I lost it, as I do...
DexterJB
Jan 23, 2018NETGEAR Moderator
Hi goclmbmnt,
1. What is the firmware version of the router?
2. What version of the Genie app do you have installed?
3. Please make sure that both iTunes and Adobe Reader are up to date.
4. What version of iOS are your devices using?
Dexter
Community Team
- DexterJBJan 26, 2018NETGEAR Moderator
Hi goclmbmnt,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- cameronc1Mar 27, 2018Tutor
Hi,
I'm having this issue as well
Firmware - V1.0.9.26
iOS - 11.2.6
Since i updated firmware, Airprint no longer works.
- chavo567Apr 08, 2018Aspirant
I also have the same issue. My AirPrint printer Canon MF726Cdw shows that it is connected to the network but my laptop cannot discover it. The printer also does not show up in the attached devices.
My router firmware version is V1.0.9.26_10.2.31 .
