goclmbmnt
Dec 10, 2017Tutor
Airprint stopped working - R7000
I get an error message on my ios devices when I try to print to my non-airprint compatible printer setup through the router. It used to work great. I loved it. I'm not sure when I lost it, as I do...
DexterJB
Jan 26, 2018NETGEAR Moderator
Hi goclmbmnt,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
cameronc1
Mar 27, 2018Tutor
Hi,
I'm having this issue as well
Firmware - V1.0.9.26
iOS - 11.2.6
Since i updated firmware, Airprint no longer works.
