Jeanmac444
Dec 04, 2024Follower
All Netgear apps say C7000v2 supported even though Nighthawk should
I moved and took my C7000v2 modem router with me. I set up using the Nighthawk app. I recently had to factory reset (for Xfinity) and the Nighthawk app says product not supported. The Genie app says I...
michaelkenward
Dec 04, 2024Guru - Experienced User
Sadly, the reset may be automatic thing to suggest, but it is a bit of a sledgehammer approach. It wipes out all your previous settings.
The problem is that when you move from one place to another, you can end up with completely different ISP settings. And the Nighthawk app is too dumb to manage that.
Getting into the C7000v2 with a web browser and the graphical user interface (GUI) gives you more control.
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
If you can get that far you can then put the modem/router through its internet setup wizard. If all goes well, the other local settings should stick.
They confirmed I’m on latest firmware.
Firmware is a red herring for cable modem/routers. You can't do anything about out. That is down to the ISP.
Just another user with time on their hands.
