_Fletch
Jan 20, 2016Aspirant
Android Genie App Cannot be Uninstalled
When I try to uninstall the app, the Genie splash screen opens up and then freezes. Only option is to pull my battery. FWIW: LG G4
- Jan 25, 2016
I rooted my phone and was then able to just delete all the Netflix Genie App crap. I'm all clean now. Thanks for trying to help.
_Fletch
I've tried that numerous times. Same result.
DexterJB
Jan 20, 2016NETGEAR Moderator
Hi @_Fletch,
Please try installing over an older version of the app and then uninstall it. You may use the download link for the previous version below.
http://files.netgear-support.com/go/?a=d&i=ufqGki7Q92
Dexter
Community Team
- _FletchJan 21, 2016Aspirant
The install process errors out.
"X Application Not Installed"
- DexterJBJan 23, 2016NETGEAR Moderator
Hi @_Fletch,
1. Are you able to install and uninstall other applications on your phone?
2. Does the issue occur on any of your other Android devices?
3. Have you tried uninstalling it through the Google Play Store and not through the settings?
Dexter
Community Team
- _FletchJan 25, 2016Aspirant
