dslpow3r
Sep 20, 2014Aspirant
Android Genie App questions
Just bought the R6100 AC 1200 router. When I use the smartphone app and go to the Network App, there is a red line going from the globe to my wireless router. My wireless works, and I can do everythi...
Fairytail
Sep 22, 2014Virtuoso
The line between the globe and the router should be green which means internet is working fine. Is this an android phone or iPhone? Did you try to use different smart phones aside from the one you are using? You may try to uninstall or reinstall the Genie App.
