williamhoke
Feb 04, 2023Tutor
Android Nighthawk App Login Issues on AC (WiFi 5) Routers
If you are having login issues with the Nighthawk app on an AC (WiFi 5) router, here are some steps you can try to resolve the issue:
1. Check Internet Connection: Ensure that your device is connected to the Internet and that you have a strong and stable connection.
2. Update the app: Make sure you have the latest version of the Nighthawk app installed on your device. Updating the app may resolve login issues.
3. Restart the router: Try restarting your router and the device you are using to access the Nighthawk app. This can help resolve any temporary connection issues.
4. Verify login credentials: Double-check that you are entering the correct login information, including the username and password for your router.
5. Disable VPN: If you are using a virtual private network (VPN), try disabling it and see if you can log in to the Nighthawk app. VPNs can sometimes interfere with connections to local networks.
6. Reset the router: If none of the above steps work, try resetting your router to its factory defaults. Make sure to back up any important settings before resetting the router.
Note: These steps may vary based on your specific router and the version of the Nighthawk app you are using. If you continue to have login issues, you may want to contact the manufacturer or seek support from the Nighthawk community.
1 Reply
Also give these a try:
