Flam3shadow
Jul 05, 2022Follower
Annoying Genie-Media-Servers
Hello Comunity, i dont know since when it is but it ist a little bit annoying. At network overview on my fritzbox my pc is shown as "Genie-Media-Servers--KMHarnauGaertner-Windows" The correct n...
schumaku
Jul 05, 2022Guru - Experienced User
Grüezi Flam3shadow
Challenge AVM why they use very different name spaces for naming the devices in these connected devices view. It's clear that your Windows system was recognized before once - under the IP address 192.168.178.35 - as KMHarnauGaertner.
For some reason, your Windows system does use different IP addresses. Typical case is that it might have multiple network adapters, Ethernet; WiFi, or some legacy technology WiFi extenders doing MAC address translation. And the DHCP server does hand out one IP by MAC address.
Based on this IP address, the router does try to recognize, identify, and name the device - individually, and then based on information the Fritz! can find on the device. Here it's the DLNA (UPnP-AV) server in place as part of the Genie installation, for the "My Media" service:
So pure technically, this name can be changed.
Two questions re remaining:
1. Do you need Genie My Media sharing your local media to some DLNA systems on your LAN? If not, untick "Share my files" and "Allow play ...".
2. What is the reason you still keep the legacy Genie App operational?
Grüsse aus der Schweiz,
-Kurt
michaelkenward
Jul 07, 2022Guru - Experienced User
Possibly because it is a very useful app that does things that are a faff, or impossible, with the browser graphical user interface (GUI).
There are several features that are enough to keep it running all the time on my PCs.
If it works, don't fix it.
Is there any reason why we shouldn't keep the legacy Genie App operational?
