Legend_Bean
Mar 04, 2018Aspirant
Anyone know about ReadyShare? I've got 2 questions
How do I find out my network password? This is the screen when I try to log into a password protected folder https://i.imgur.com/7gTW0cJ.png. When I try my laptop credentials it doesn't work nor...
michaelkenward
Mar 04, 2018Guru - Experienced User
That's a Windows thing. It will depend on the network, how you have set it up, and the version of Windows.
You would do better to find a Windows forum. Or check Google/Bing.
How do I access ReadyShare on Android?
With difficulty. Investigate ReadyShare and ReadyCloud and see if your device supports them.
There is a manual for the C3700 somewhere at the end of this link:
>>>> C3700 | Product | Support | NETGEAR <<<<
You'll also find the Genie manual there.
- michaelkenwardMar 04, 2018Guru - Experienced User
