Tyler818
Aug 26, 2022Aspirant
Anywhere Accees "Something went wrong" after Factory Reset
I just finished a factory reset of my R9000 Router and I'm trying to enable Anywhere Access from the Nighthawk app. This was previously working before the Factory Reset but now when I slide to en...
- Aug 28, 2022
Remind me, did you roll back to earlier firmware to see if that helps?
michaelkenward
Aug 27, 2022Guru - Experienced User
You did have a local connection with the app?
You must be locally connected to your router to enable or disable Anywhere Access.
Have you tried using the browser graphical user interface (GUI)?
Remote Management is now Anywhere Access in the Nighthawk and Orbi apps | Answer | NETGEAR Support
Recent firmware has moved Remote Management:
>> Advanced
>> Advanced setup
>> Web Services Management
This might unclog your system.
Tyler818
Aug 28, 2022Aspirant
Yes I have a local connection within the app and I am able to do things like reboot the R9000 while connected. There is a green connected icon next to my router.
As far as this link: Remote Management is now Anywhere Access in the Nighthawk and Orbi apps | Answer | NETGEAR Support
That page states:
"...the Remote Management feature in the router or gateway web user interface functions differently from the [Anywhere Access] feature in the Nighthawk and Orbi apps.
The Remote Management feature on your router or gateway web user interface opens an external port. The Anywhere Access feature in the Nighthawk and Orbi apps uses a secure, authenticated connection through the NETGEAR Cloud and does not open any ports."
Remote Management is not enabled on my R9000 but that link indicates it is a different feature set entirely and is disabled. Also previously I had Anywhere Access working with Remote Management disabled.
- michaelkenwardAug 28, 2022Guru - Experienced User
Your call.
I have it enabled here and it seems to be a part of the process.
- Tyler818Aug 28, 2022Aspirant
For testing I thought I would try enabling Remote Management but It appears as part of my testing yesterday I turned on Remote Management and forgot so its actually been on for the last day:
My Anywhere Access issue persists with that feature enabled so I'm included to believe the Netgear page that Anywhere Access feature is a different feature from Remote Management feature.
