Tyler818
Aug 26, 2022Aspirant
Anywhere Accees "Something went wrong" after Factory Reset
I just finished a factory reset of my R9000 Router and I'm trying to enable Anywhere Access from the Nighthawk app. This was previously working before the Factory Reset but now when I slide to en...
- Aug 28, 2022
Remind me, did you roll back to earlier firmware to see if that helps?
michaelkenward
Aug 28, 2022Guru - Experienced User
Tyler818
Aug 28, 2022Aspirant
Hmm I was told to upgrade to the latest firmware to resolve an issue where the wifi SSIDs for my main and guest networks will "disappear" and disconnect all the devices.......
Is there a suggested Firmware version to use for Anywhere Access???
- michaelkenwardAug 28, 2022Guru - Experienced User
Tyler818 wrote:
Hmm I was told to upgrade to the latest firmware to resolve an issue where the wifi SSIDs for my main and guest networks will "disappear" and disconnect all the devices.......Did you see that on your router?
Is there a suggested Firmware version to use for Anywhere Access???Try the one that worked for you.
