Ziquiel
Jan 16, 2023Tutor
Anywhere Access Failure in RAX200
I was having rouble access to Anywhere Access. So I disabled it and then try to enable it. When it disabled without an issue. But getting the error to try again when I enable it. The error is "...
- Jan 17, 2023After a week of trying various things.
The last thing was submitting a bug report.
For grins and giggles I decided to try it again. Now, it is miraculously working. I was able to turn it on.
To confirm that it worked I closed the app. Switch to cellular and connect thru the app. I was able connect thru Anywhere Access.
So I have no idea what happened. I am convinced at this time that someone saw something wrong in their cloud and fixed it.
I double checked and my app was not updated and I don’t see a firmware has been updated.
Ziquiel
Jan 16, 2023Tutor
I did originally reset this with a factory reset and the app.
So I will try the bug report.
Thank you.
Thank you.
Ziquiel
Jan 17, 2023Tutor
