TheComputerHyp
Sep 03, 2020Guide
"Anywhere Access" in Nighthawk app not working
Just bought a new RAX75 router and am trying to access it remotely via the Nighthawk app "Anywhere Access" feature. App works great while I am at home logged into my network via wifi. Here's what I ...
TheComputerHyp
Sep 05, 2020Guide
Yes. One oif the first things I did was turn on "Enable Anywhere Access" within the app settings.
schumaku
Sep 06, 2020Guru - Experienced User
Disable and re-enable in the App does not help?
Using ISP DNS potentially blocking useful services?
- TheComputerHypSep 11, 2020Guide
I deleted and reinstalled the app. That did not cure the problem.
I have never had any problems with my ISP blocking anything. And by the way, I was successfully using this app with my prior Netgear router to access it remotely. This problem only occured when I migrated to a new Netgear router (RAX75).
- Bing2020Oct 13, 2020Aspirant
Hi TheComputerhyp
unisntall/reisntall app does not cure this issue.
Here is my suggestion:
1. reboot your RAX75/80
2.after boot up, connect mobile phone to your RAX75/80 and then launch app to dashboard
3. Lead to page "Dashboard -> hambur menu --> Settings-->Anywhere Access
4.Turn off and then turn on toggle button "Enable Anywhere Access". Just re-enable Anywhere Access.
check if you can renable success, if yes, then check if still show offline remotely,
Thanks!
