TheComputerHyp
Sep 03, 2020Guide
"Anywhere Access" in Nighthawk app not working
Just bought a new RAX75 router and am trying to access it remotely via the Nighthawk app "Anywhere Access" feature. App works great while I am at home logged into my network via wifi. Here's what I ...
paulroady
Oct 09, 2020Aspirant
In the app i slide the button to green but it auto goes back to grey/white.
Is there a fix to this?
netgear app version 2.6.4.1264
router version 1.0.3.102
Christian_R
Oct 12, 2020NETGEAR Employee Retired
Hi paulroady,
Have you had a moment to setup anywhere access within the router's admin page?
Christian
- schumakuOct 12, 2020Guru - Experienced User
Christian_R completely new there should be a control to enable Access Anywhere control in the routers Web UI...
Newer router User Manuals (e.g. Nighthawk AX8 User Manual from p.110) just make a mess mixing the terms "Remote Access" in the section title following by "Setup Remote Management" and later on for using what is configued above "Use Remote Access".
None of this is related to the Access Anywhere, except the next completely confusing section titled "Remotely Access Your Router Using the Nighthawk App".
"You can use the Nighthawk app to remotely access your router and change its settings.
Before you can use remote access with the Nighthawk app, you must update your
router’s firmware and download the latest Nighthawk app for your mobile device."The key that Access Anywhere (formerly named Remote Management, but not as per above using na exposed port 8080!) can only be enabled in the App - and never on the router Web UI.
