GavinBates
Nov 06, 2024Aspirant
Anywhere Access option for RAX43
 Hey Team.     Im struggling to find an option to remotely shut my children off the internet using my RAX43 when I saw that Anywhere Access would be the perfect solution.     I cannot connect to the r...
- Nov 08, 2024
What FW is loaded on the router?
What phone or pad platform are you using?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageHave you factory reset the router and setup from scratch with the Nighthawk app?
Nov 08, 2024Guru - Experienced User
GavinBates
Nov 10, 2024Aspirant
Hey.
Thanks for the reply. I reset the router and reinstalled the app with no apparent effect. Then went to try again a few days later and the option for Anywhere Access was on my setting and works perfectly away from my WIFI.
- FURRYe38Nov 11, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
