richpizz
Dec 16, 2022Tutor
Anywhere Access "Something went wrong" R6700V3
Have latest firmware V1.0.4.128 app will not let me enable anywhere access. R6700V3 router.
michaelkenward
Dec 18, 2022Guru - Experienced User
richpizz wrote:
...app will not let me enable anywhere access.
Which app? iOS or Android?
How are you going about this and what happens when you try?
richpizz
Dec 18, 2022Tutor
I have the Nighthawk app on an Android phone. I open the app while in the wifi of the router and go to settings then Anywhere Access and Enable Anywhere Access. After a while I get message something went wrong. I have retried many times on different days. Others have reported same problem with different Nighthawk routers. They believe it is a problem in the firmware.
