richpizz
Dec 16, 2022Tutor
Anywhere Access "Something went wrong" R6700V3
Have latest firmware V1.0.4.128 app will not let me enable anywhere access. R6700V3 router.
richpizz
Dec 18, 2022Tutor
I have the Nighthawk app on an Android phone. I open the app while in the wifi of the router and go to settings then Anywhere Access and Enable Anywhere Access. After a while I get message something went wrong. I have retried many times on different days. Others have reported same problem with different Nighthawk routers. They believe it is a problem in the firmware.
michaelkenward
Dec 18, 2022Guru - Experienced User
Does the Android app work apart from Anywhere Access?
In theory, Anywhere Access gets turned on by default:
Why is Anywhere Access enabled by default on my NETGEAR or Orbi router? | Answer | NETGEAR Support
Note the bit about managing a router with Anywhere Access.
If you find that Anywhere Access is not enabled, you could try a "factory reset".
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Bit of a nuisance. You can backup your settings – always a good idea anyway – before you try that. Just in case it fails and you want to restore the settings.
- richpizzDec 18, 2022Tutor
Yes, other than Anywhere Access the App works fine.
- michaelkenwardDec 18, 2022Guru - Experienced User
And the rest?
- MGogulapatiDec 18, 2022Tutor
I've similar issue with my RAX48 router after latest router firmware upgrade (V1.0.11.112} and everything else seems to be working ok. I can't seem to make it enable anymore.
MG
