szeeman
Oct 11, 2022Aspirant
Anywhere Access using the nighthawk app does not work for R7000P wifi router?
I have the Netgear R7000P wifi router and CM600 cable modem. I recently downloaded the Nighthawk iPhone app. I can easily connect to the router locally using the app, but when I attempt to enable Any...
- Oct 13, 2022
szeeman wrote:
I used the netgear app to update to the latest fw, and the app confirmed that I am using the latest fw. BUT, when I look up the latest fw in netgear support, as suggested by another responder, it turns out that I DO NOT have the latest fw. If I really want the latest fw, apparently I have to download it from support and then install it. In other words, the app/GUI tells me that I have the latest fw, when in fact I do not.
I couldn't agree with you more. Netgear's firmware update system is nuts.
That is why a regular question here asks for the firmware version, the number, because claims of "the latest" can be bogus.
Oct 11, 2022Guru - Experienced User
What version of the app do you have loaded?
Are you able to connect locally with the app?
- szeemanOct 11, 2022Aspirant
Forgot to mention, I checked that it was upadated: V1.3.1.64_10.1.36
- FURRYe38Oct 11, 2022Guru - Experienced User
I see more recent version of FW available:
https://www.netgear.com/support/product/R7000P.aspx#download
I would sign out of the NH app fully. Log out.
Update the FW on the router. Factory reset and setup from scratch using a wired PC and web browser. Once the router is setup again, Try logging into the NH app and see if Anywhere Access is enabled. Should be by default.- szeemanOct 11, 2022Aspirantwell, i had it set for auto update of firmware AND I pushed it to update the fw before i downloaded the app, to which it responded that that the fw was already up to date. So if the fw that i posted is not the most current fw, then netgear's update system is whack.
