szeeman
Oct 11, 2022Aspirant
Anywhere Access using the nighthawk app does not work for R7000P wifi router?
I have the Netgear R7000P wifi router and CM600 cable modem. I recently downloaded the Nighthawk iPhone app. I can easily connect to the router locally using the app, but when I attempt to enable Any...
- Oct 13, 2022
szeeman wrote:
I used the netgear app to update to the latest fw, and the app confirmed that I am using the latest fw. BUT, when I look up the latest fw in netgear support, as suggested by another responder, it turns out that I DO NOT have the latest fw. If I really want the latest fw, apparently I have to download it from support and then install it. In other words, the app/GUI tells me that I have the latest fw, when in fact I do not.
I couldn't agree with you more. Netgear's firmware update system is nuts.
That is why a regular question here asks for the firmware version, the number, because claims of "the latest" can be bogus.
Oct 11, 2022Guru - Experienced User
What version of the app do you have loaded?
Are you able to connect locally with the app?
szeeman
Forgot to mention, I checked that it was upadated: V1.3.1.64_10.1.36
- FURRYe38Oct 11, 2022Guru - Experienced User
I see more recent version of FW available:
https://www.netgear.com/support/product/R7000P.aspx#download
I would sign out of the NH app fully. Log out.
Update the FW on the router. Factory reset and setup from scratch using a wired PC and web browser. Once the router is setup again, Try logging into the NH app and see if Anywhere Access is enabled. Should be by default.- szeemanOct 11, 2022Aspirantwell, i had it set for auto update of firmware AND I pushed it to update the fw before i downloaded the app, to which it responded that that the fw was already up to date. So if the fw that i posted is not the most current fw, then netgear's update system is whack.
Some FW may not be seen on the auto update system. So it's up to users to manually check and manually update FW.
