szeeman's avatar
szeeman
Anywhere Access using the nighthawk app does not work for R7000P wifi router?
I have the Netgear R7000P wifi router and CM600 cable modem. I recently downloaded the Nighthawk iPhone app. I can easily connect to the router locally using the app, but when I attempt to enable Any...
  • michaelkenward's avatar
    michaelkenward
    Oct 13, 2022
    szeeman wrote:
    I used the netgear app to update to the latest fw, and the app confirmed that I am using the latest fw. BUT, when I look up the latest fw in netgear support, as suggested by another responder, it turns out that I DO NOT have the latest fw. If I really want the latest fw, apparently I have to download it from support and then install it. In other words, the app/GUI tells me that I have the latest fw, when in fact I do not.
    I couldn't agree with you more. Netgear's firmware update system is nuts.
    That is why a regular question here asks for the firmware version, the number, because claims of "the latest" can be bogus.
