R-J-R
Sep 16, 2020Tutor
ANYWHERE ACCESS
Ever since the change from remote access to anywhere access, I have not been able to remotely access my router. I have attached a picture of the error message. When I go to enable it ot is says someth...
R-J-R
Sep 20, 2020Tutor
MESH MR60
V 1.0.6.102
V 1.0.6.102
- R-J-RSep 20, 2020TutorPlease see the screen shots ofbthe error messages. First on tells you to go to settings to Enable Anywhere Access, when you go there to enable it it tells you something went wrong, and then the messge pops up sayingbit is already registered to another device.
- michaelkenwardSep 20, 2020Guru - Experienced User
R-J-R wrote:
MESH MR60
V 1.0.6.102You might do better asking here:
Nighthawk Mesh System - NETGEAR Communities
- R-J-RSep 20, 2020TutorThank You!
