CherryMI
Nov 29, 2022Tutor
Anywhere Access
I was told by Netgear support that there is an ongoing problem currently using Anywhere Access from my Mobile Device. Does anyone know if there is a timeframe to resolve. When I try to access my ro...
Nov 29, 2022Guru - Experienced User
Yes and no, NG doesn't post when this will be fixed.
What mobile platform are you using?
Can you connect while at home on local network?
What NG model router do you have?
CherryMI
Nov 29, 2022Tutor
I can connect while connected to the local network and I am on an Apple IOS. I have seen this happened every now and then but it always resolves itself. The router is a Nighthawk R7000P.
Since I am away from home at the moment, I had a friend go cycle the router and this did not resolve the issue.
