Giovanni_L
Apr 24, 2025Guide
App broken?
Since updating the Nighthawk app on my iPhone to the latest version (2.44.0), I can no longer log into my R7800 Nighthawk router, which I was able to manage without problems before. Attached is a sc...
- May 26, 2025
Yeah, the App is finally fixed (at least for my R7800 router). v2.45.1.1 (released and installed today) did it!
Now I can log in without any problems and see all my devices connected to the router.
SM007
Jul 01, 2025Tutor
Login to app on iPhone still not working after latest app update. RAX75
- FURRYe38Jul 01, 2025Guru - Experienced User
I noticed with my RAX80, the app seems to log in with Anywhere Access. However when I attempt to change over to Local Only, All fails after that. Even coming back to AA connection, starts failing. I submitted bug reports thru the app for this. Recommend doing the same.
- SM007Jul 01, 2025Tutor
I have same/similar scenario. Noticed AA was enabled. Was able to disable it, shows connected locally but then will prompt to log into router on its own and get timeout message again.
Ya, Local is broke and seems to break AA if attempted to use that path.
