warhorseman1
May 13, 2020Aspirant
App not compatible with phone (RAX35)
The wifi app is not compatible with my phone, is there an alternative app or PC download for this?
What phone are you using? I know the android and iOS apps work.
You can set it up using the brower based method from the manual.
manual can be found here:
- warhorseman1Aspirant
It's a TCL A501DL (Basically a cheap $30 Wal-mart Phone)
- plemansGuru - Experienced UserAgain, you can set it up via the browser.
Not sure why you're getting the app isn't compatible. That phone runs android 8.1 which has a nighthawk app.
