Mommytwinz
Dec 12, 2019Aspirant
App says offline but everything is woking
So my app is saying that athe router is offline but all the features are working just fine. When I click the home button and look for my products there is a green light next to the router. is this an...
DexterJB
Dec 18, 2019NETGEAR Moderator
Hi Mommytwinz, welcome to the community! Please provide a screenshot of the app page. Also, is this the Android or iOS version? The C7000 (indicated on the footer) is not among the models that support the Nighthawk app. Please check the model number and firmware version of your router.
Dexter
- MommytwinzDec 18, 2019AspirantIt only says offline every so often. Android phone
- DexterJBDec 19, 2019NETGEAR Moderator
- MommytwinzDec 19, 2019AspirantNo I do not.
- DexterJBDec 22, 2019NETGEAR Moderator
Hi Mommytwinz, we will have this check on our end. Does the issue persist if you enable Remote Management?
Dexter
- MommytwinzDec 22, 2019AspirantThe router ended up dying a few days ago and I got a r7000p 2300 instead
