Mommytwinz
Dec 13, 2019Aspirant
App says offline but everything is woking
So my app is saying that athe router is offline but all the features are working just fine. When I click the home button and look for my products there is a green light next to the router. is this an...
tregan01
Jun 08, 2020Guide
I am having the same issue. I am connected to the router on my iMac, iPhone, and Apple TV. However, when I tried opening the Nighthawk app to check for any updates, the app will not connect. It says the router is offline, even though all the lights on the router are green, and as mentioned, I am connected on all my devices (see attached)
- Christian_RJun 10, 2020NETGEAR Employee Retired
Hello tregan01,
May you try reinstalling the Nighthawk app on your mobile device.
Christian
- tregan01Jun 16, 2020Guide
Not only did that not work, but now, even though some devices are online, connected to my network, but some devices are not, and when I enter my password for my network, I am receiving an error that the password is incorrect. However, if I reboot the router, everything is connected again. Although I have been rebooting both my modem and router almost every day for the last week.
- Christian_RJun 18, 2020NETGEAR Employee Retired
Hi tregan01,
Would you mind providing us with the following info for us to check further.
Router Model:
Router Firmware Version:
App Version: (iOS or Android)
Thanks,
Christian
