Mommytwinz
Dec 12, 2019Aspirant
App says offline but everything is woking
So my app is saying that athe router is offline but all the features are working just fine. When I click the home button and look for my products there is a green light next to the router. is this an...
tregan01
Jun 08, 2020Guide
I am having the same issue. I am connected to the router on my iMac, iPhone, and Apple TV. However, when I tried opening the Nighthawk app to check for any updates, the app will not connect. It says the router is offline, even though all the lights on the router are green, and as mentioned, I am connected on all my devices (see attached)
Christian_R
Jun 10, 2020NETGEAR Employee Retired
Hello tregan01,
May you try reinstalling the Nighthawk app on your mobile device.
Christian
