ebaba
Jun 04, 2022Follower
APP with 2 different homes possible?
Hello, I would like to to controll my main home and an independent holiday home with the APP, but it seems this is not possible. Any idea how I can setup 2 different homes with the APP? Thanks
michaelkenward
Jun 07, 2022Guru - Experienced User
Which devices?
If they support Anywhere Access, then you can use an app to manage both routers.
You may have to check your devices' manuals for setting up Remote Management.
Remote Management is now Anywhere Access in the Nighthawk and Orbi apps | Answer | NETGEAR Support
