Dawgsfan7
Nov 30, 2018Initiate
App won’t let me save device names
So for a while now my Netgear app won’t let me save custom names to devices. It used to save them fine and one day it stopped working. It’ll change the name then when I save and refresh the network m...
michaelkenward
Dec 01, 2018Guru - Experienced User
And the concerned hardware is?
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
- Dawgsfan7Dec 01, 2018Initiate
This is my router. Sorry not a huge tech guy, hope this is enough to help. Firmware is up to date. Simply a home router. No modem used with router.
- michaelkenwardDec 02, 2018Guru - Experienced User
So, it is an R7000P. There is a manual for the R7000P somewhere at the end of this link:
>>> R7000P | Product | Support | NETGEAR <<<
Yes, but what is the number? Just because it says it is up to date does not guarantee that this is true. Newer stuff may not have reached the update servers.
Something has to deliver the internet to you. What is plugged into the yellow socket on the back of the router?
- Max33510Apr 24, 2019InitiateDon't be such an arrogant **bleep**
- michaelkenwardApr 25, 2019Guru - Experienced User
NETGEAR-Community-Terms-Of-Service
Behave with civility and mutual respect. Flaming or name calling will not be tolerated.- rjleurckApr 27, 2019Initiate
Firmware R6400v2 V1.0.3.66_10.0.50
Same issue Nighthawk IOS app 2.3.1.37 Iphone SE IOS 12.2
The Devices menu allows you to edit and save a name for your device. But if you navigate out of the menu and back the saved names revert to the original "-"
Is this a known bug ?
The router web interface does allow saving a device name :-)
