Dawgsfan7
Nov 30, 2018Initiate
App won’t let me save device names
So for a while now my Netgear app won’t let me save custom names to devices. It used to save them fine and one day it stopped working. It’ll change the name then when I save and refresh the network m...
kboy24
Dec 09, 2019Apprentice
I managed to change my Devices names using the Nighthawk App. Took effect on my Iphone and on the Router for now. Will Monitor and let ya know. Version 2.4.12.4
- DehatterDec 09, 2019TutorThe issue is that if you logon your router’s web interface, your names and device icons will not match.
The router’s web interface has a smaller field and more limited text options (including no spaces allowed).
For some reason Netgear, in its infinite wisdom, has allowed 2 different systems to name and identify devices that do not work with each other.
Perhaps I do not understand the issues that Netgear faces but from a customer side it is both confusing and frustrating.
If you only access your router from the mobile app then you will not notice an issue. Similarly, if you only access from the web interface you will have no issue. The name changing only happens if you want the use them together (usually because the web interface can’t understand the app names if you have used spaces or other ineligible characters).- RichDeweesDec 09, 2019Apprentice
Yes, the LAN setup screen has a limited # of characters. But, it's the admin and secrity names that are my issue. Once of my devices keeps changing back even if it is changed in the app, chages on the GUI, but at some point changes back to standard name on the GUI only. App still has the names I gave them...
- kboy24Dec 15, 2019Apprentice
This has become so buggy it's a damn joke Netgear. Your products and your responses to our problems with this is non-exsistent. Another thing I tried your Armor and boy is that a load of crap.
- ncdancerFeb 22, 2020Guide
If you only access your router from the mobile app then you will not notice an issue. Similarly, if you only access from the web interface you will have no issue. The name changing only happens if you want the use them together (usually because the web interface can’t understand the app names if you have used spaces or other ineligible characters).Yes I have experienced the same problems and others too. I agree the two systems have a conflict with naming of devices in the app and on router login.
Also sometimes the custom icons I have assigned to my devices disappear and return to the generic icon, then they return if I quit the app and open it back up again. Also the the signal strength icons don't work when my custom icons are visible and the 5GHz and 2.4GHz are not separated but all under one wirless listing.
IMO, there are lots of problems with the app.
- ScgApr 03, 2020GuideI've been fighting this issue myself. I have an R6400 router. Firmware is up to date. My cell phone names seem to stay okay as do my desktop computers. And printers always come up with their own names, but they are self-explanatory so I don't need to change them. My doorbell comes up with a name automatically that I recognized so I left it alone.
The problem is all my kids Chromebooks from school. I named them and then sometimes immediately after refreshing the names are gone. Sometimes the names hang around for a few days but eventually they all revert back to a generic "--unknown" name.
I'm juggling 6 Chromebook so I constantly have to ask them for their IP addresses which change all the time in order to know whose is whose.
I've tried changing them both on the phone app as well as the desktop website.
Any words of wisdom? I have read through all the previous posts
