Adj
May 30, 2019Follower
Are NETGEAR Nighthawk app compatible to R6250 and EX6150
Hi, As NETGEAR Nighthawk app will replace GENIE app, it will be compatible to R6250 ans EX 6150? The compatibility chart does not show these two routers models. thanks
michaelkenward
May 31, 2019Guru - Experienced User
The Nighthawk app does not generally support extenders.
Any devices that do not work with the Nighthawk app can continue to use the genie.
To find which apps and programs support your device, visit its support pages and look for downloads.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
