SickAgent
Feb 04, 2017Tutor
Auto login for NETGEARGenie
BLUF: NETGEARGenie logs in automatically. We have parental controls set up, but it's essentially open for anyone to shut it off because the application automatically logs in. I cannot find anywhere t...
DexterJB
Feb 07, 2017NETGEAR Moderator
Hi SickAgent,
You can uninstall the program from the computer and install the mobile version for either Android or iOS on your own mobile device. You will be able to manage the filtering level for each of the connected device just the same.
Dexter
Community Team
- SickAgentFeb 11, 2017Tutor
I appreciate the response and the idea. That's a possibility, but the mobile app doesn't have nearly the controls and overall features the PC or Mac version does.
Is there really no functionality within the program to no leave the parental controls wide open? That seems like a major architectural flaw.
- DexterJBFeb 12, 2017NETGEAR Moderator
Hi SickAgent,
You are correct that the PC/Mac version does have more features built in to them but the mobile versions should have the same functionality when it comes to the Parental Controls feature. Unfortunately, there is no way to logout of the Parental Controls feature. This is something that you can suggest using the link below.
Dexter
Community Team
- SickAgentFeb 14, 2017Tutor
Dexter,
Thank you for helping me through all this and for the link! I've submitted the idea already.
V/r,
Dale
