cmarger
Jun 17, 2022Initiate
AX1800 Wifi Extender - Moved to different room - now wont show up on nighthawk app
Set up my extender near my router. Worked fine and showed up on Nighthawk app. After setup, I moved to a different location. It seems to be working, but I can no longer see the status on the Nighthaw...
- Jun 18, 2022
Glad to hear you got it working, you might mark it as solved so others aren't trying to fix it still 🙂
Jun 18, 2022Guru - Experienced User
Are you connected to the extender with the phone?
Also, log into your router and find the ip address for the extender. Try logging into the extender with its ip address
