cmarger
Jun 17, 2022Initiate
AX1800 Wifi Extender - Moved to different room - now wont show up on nighthawk app
Set up my extender near my router. Worked fine and showed up on Nighthawk app. After setup, I moved to a different location. It seems to be working, but I can no longer see the status on the Nighthaw...
- Jun 18, 2022
Glad to hear you got it working, you might mark it as solved so others aren't trying to fix it still 🙂
