stevengates45
May 30, 2021Tutor
Bit Defender / Parental Controls WiFi Drop
I have an RAX48 router and lately, the WiFi sporadically kicks all clients offline. The WiFi signal is still discoverable but no devices can connect to it without first restarting the router. To mitigate, I disabled Netgear Armor and Smart Parental Controls. As soon as I disabled the app, the random WiFi disconnections have stopped and my WiFi speeds have significantly increased to certain WiFi clients. I'm uncertain which of these apps is the root cause but I'm leaning towards Netgear Armor at the moment. I'm not asking for a technical solution to the problem, this post is simply to notify Netgear that something with these 2 apps is causing random WiFi disconnections.
Sort By
You might have m,ore success ingetting through to the right peo;lpe if you posted that here:
NETGEAR Armor - NETGEAR Communities
and/or
Circle Smart Parental Controls - NETGEAR Communities
The app, the subject of this section, is just a way into the controls. It probably has nothing to do with the behaviour you see.
michaelkenward Considering Armor and Smart Parental Controls are only enabled and modified through the Nighthawk app, I think placement of my post is fine. As you mentioned I could have posted my original comment in both or either one of the threads you listed and I almost did just that. Ultimately I decided that placing the post anywhere other than this thread would add very little value if any at all.
You are free to post wherever you like. I didn't want you to be disappointed if your message in this section went unanswered. Too many people turn up here with messages about apps that then get ignored, especially when they don't say which app they mean. (Sadly, perhaps because Google and Apple are at daggers drawn, Netgear cannot get its apps to be identical.)
Things like Armor and Smart Parental Controls are not exclusive to the app. You can also play around with them in the browser graphical user interface (GUI), where experienced users like to do things.
Then there is the fact that Armor and Smart Parental Controls have specific sections
where people can raise issues. It is puzzling that someone who wants to talk about Armor and Smart Parental Controls doesn't want to visit those places. But, as I say, it is your choice.
Then there is the possibility that it may have something to do with your hardware.
Oh, and any talk of "this thread" is odd. This thread is not some long running conversation about an important topic, but your first message and a follow-up refusal to alert people who might be interested in what you are saying.
