Nigor
Jan 13, 2016Aspirant
Browser netgear genie v1.2.12 can't click simple or advanced tab
Hey there, Since a few months now, I can't access advanced tab on my browser netgear genie because it's impossible to click on it, well, it highlights but the click doesn't load nor reacts. ...
DexterJB
Jan 13, 2016NETGEAR Moderator
Hi @Nigor,
1. Have you tried using another device (another computer, smartphone, tablet)?
2. Have you tried performing a power cycle (turning off then on)?
3. Have you tried resetting the router?
Dexter
Community Team
- NigorJan 21, 2016Aspirant
Hi, I tried using my smartphone, who has the same issue with chrome and base android browser.
The modem has been switched off and on multiple times, and even reset, I had to set the parameters (password and name).
The issue is the same, without improvement. I'd like to try another (older) version of the router, but it seems like I can't install another version anyhow.
Thanks for your attention.
- DexterJBJan 23, 2016NETGEAR Moderator
Hi @Nigor,
1. What is the model number of your device?
2. Did you perform the reset by pushing the small button on the unit? If not, please refer to the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
- NigorJan 26, 2016Aspirant
Well I have a few numbers and to be honest I don't know which one is the one you'd like to get.
Numbers :
IC: 4054A-10200135
FFC ID: PY301200135
MAC: 204E7F7EC55E
SERIAL: 2SV11A5W00DE2
Yes, I have pushed the "restore factory settings" button with a pointy object and had to reset the connection using the security pin (I think it was that one) and made a brand new wi-fi network.
