Bcole
Mar 04, 2017Aspirant
Bug - genie 3.1.12 android network map unable to change device type on hosting device
Unable to change device type of the hosting genie device.
schumaku
Mar 04, 2017Guru - Experienced User
If the hosring device == the Android device where the Qenie App is running ... confirmed.
Why ever, I can't see your screenshot ... just a triangle.
- michaelkenwardMar 04, 2017Guru - Experienced User
schumaku wrote:Why ever, I can't see your screenshot ... just a triangle.
They take time to land. Come back later.
- schumakuMar 04, 2017Guru - Experienced User
You might be right ... open in new windows shwos some kind of unmoderated.gif
Are images moderated?
schumaku wrote:If the hosring device == the Android device where the Qenie App is running ... confirmed.
Yup. Hosting device is what you say. That one baffled me too.
Solved: Re: Bug - network map not saving custom name on de... - NETGEAR Communities
PS There is a spell check button up above. Far right.
