Bcole
Feb 25, 2017Aspirant
Bug - genie network map - pause internet - swipe left-right to enable and disable
To pause Internet, swipe to turn off is left to right instead of right to left
- Mar 05, 2017
With 3.1.12 the widget acts on a double tap instead of a swipe on a Samsung sm-t350 8 inch tablet. Android 6.0.1
Omaha my Samsung 5S sm-G900v swipe toward right to pause Internet, swipe to the left to disable pause Internet. Android 6.0.1
Guess the screen size is causing the tablet to behave differently than the phone.
michaelkenward
Feb 26, 2017Guru - Experienced User
Bcole wrote:To pause Internet, swipe to turn off is left to right instead of right to left
What does this mean?
What app?
Netgear has several of them.
Bcole
Feb 26, 2017Aspirant
Genie
Version 3.1.10
Router R7000
Firmware v1.0.7.10
- michaelkenwardFeb 26, 2017Guru - Experienced User
That is the Android genie.
There are also genies for ios, Windows and macs.
There is no "pause internet" feature here.
- BcoleFeb 26, 2017Aspirant
So on the genie app v 3.1.10 on android there is a pause Internet option and the slide switch is enabled with a left to right swipe. To disable a right to left swipe should work but does not. A left to right swipe, again will disable.
- BcoleMar 05, 2017Aspirant
