Bcole
Feb 25, 2017Aspirant
Bug - network map not saving custom name on device hosting genie
3.1.10 genie On the main screen displays the custom name of my android tablet but does not show the same on the network map. Restart the app and on the first page displays the original nam...
- Mar 04, 2017
Version 3.1.12 has fixed this problem
Bcole
Feb 26, 2017Aspirant
If you click around the text "unknown", usually around the middle, I get a cursor and my keyboard appears.
Seems to be a boundary issue with the text field, where the two characters on the right will not accept click into field.
michaelkenward
Feb 26, 2017Guru - Experienced User
What I meant was that I can change the name, but it does not save the new name, even on a per session basis.
I can change the "Type" and that does stick.
- BcoleFeb 26, 2017Aspirant
I was able to change and save all of the custom names and types except for the device that hosting genie.
Thought it might be the bypass but set that to default to router and still not able to save.
Also, the is no type field for the genie hosting device
- michaelkenwardFeb 26, 2017Guru - Experienced User
Bcole wrote:Also, the is no type field for the genie hosting device
I was referring to the Android genie.
I have no idea what the "genie hosting device" or "device hosting genie" refer to.
The genie hosting device is the android device that has the genie app installed on it.
The custom names are stored on the device that has the genie app installed.
It appears that the device that has genie app installed can not change the name or type of the hosting device.
