Bcole
Feb 25, 2017Aspirant
Bug - network map not saving custom name on device hosting genie
3.1.10 genie On the main screen displays the custom name of my android tablet but does not show the same on the network map. Restart the app and on the first page displays the original nam...
- Mar 04, 2017
Version 3.1.12 has fixed this problem
michaelkenward
Feb 26, 2017Guru - Experienced User
What I meant was that I can change the name, but it does not save the new name, even on a per session basis.
I can change the "Type" and that does stick.
Bcole
Feb 26, 2017Aspirant
I was able to change and save all of the custom names and types except for the device that hosting genie.
Thought it might be the bypass but set that to default to router and still not able to save.
Also, the is no type field for the genie hosting device
- michaelkenwardFeb 26, 2017Guru - Experienced User
Bcole wrote:Also, the is no type field for the genie hosting device
I was referring to the Android genie.
I have no idea what the "genie hosting device" or "device hosting genie" refer to.
- BcoleFeb 26, 2017Aspirant
The genie hosting device is the android device that has the genie app installed on it.
The custom names are stored on the device that has the genie app installed.
It appears that the device that has genie app installed can not change the name or type of the hosting device.
Bcole wrote:It appears that the device that has genie app installed can not change the name or type of the hosting device.
It seems that you can change the type and name of other Android devices. But not the one that hosts the app.
On my Nexus 4, I can change the other Android to a Nexus 7. But the Nexus 4 is stuck.
On my Nexus 7, I can change the other Android to a Nexus 4. The Nexus 7 is stuck.
Hang on, look at the Router Management bit of the app and scroll through Connected Devices. There you will see that the devices have the names that the desktop genie has for them.
The Android app also shows my Arlo camera as a wifi device whereas the Windows app says it is wired.
