Bcole
Mar 04, 2017Aspirant
Bug genie 3.1.12 android traffic meter not displaying data
The traffic meter is not displaying data even when enabled.
Bcole
Mar 05, 2017Aspirant
Samsung sm-t350 8 inch tablet Android 6.0.1
Samsung S5 SM-G900V phone android 6.0.1
Netgear R7000 firmware v1.0.7.10_1.2.3
Neither genie apps 3.1.12 are displaying data on the traffic monitor graphs
On the router's www.routerlogin.net, advanced home - LAN Port - Show Statistics is showing data for WAN and the 2.4G WLAN b/g/n and the 5G WLAN a/n/ac
So the r7000 router appears to be gathering the data but the data is either
1. Genie not requesting the data from the router
2. Router not doing the calculations and storing the averages
- schumakuMar 05, 2017Guru - Experienced User
You are not alone -> https://community.netgear.com/t5/Genie/Netgear-Genie-for-Android-Latest-version-no-longer-reporting/m-p/1235931#U1235931
- JohnnyFRXMar 06, 2017Apprentice
The Genie updated to v4.0 on my Amdroid and the problem seems to be resolved now.
- schumakuMar 06, 2017Guru - Experienced User
JohnnyFRX wrote:The Genie updated to v4.0 on my Amdroid and the problem seems to be resolved now.
Source? Noting like a 4.0 in Play Store. Suspect you mixed the App version (here: 3.1.12 around since around end of February, same as in the subject) with the [much to high] 4.0 Stars...
Well possible, there are dependencies with the router model and currently installed firmware - please provide details.
